-- Fender flares |
| Sierra |
Verfasst am: Fr, 01. Nov 2002, 17:37 |
Anmeldungsdatum: 01.11.2002
My HZJ78 has just been equiped with a set of AT 235-85-R16 and OME suspensions. With this setup, my truck is getting quite dirty even in normal driving conditions...quite normal given the new height of the vehicle.
Would anyone have any recommendations on a set of fender flares that would fit the HZJ78, ideally with a mounting system that would avoid making holes in the body / underbody.
thanks, |
_________________ SierraHZJ78 - 235/85R16 - OME Heavy - 180 L Tank -- and still building the beast... |
| MartinRR |
Verfasst am: So, 03. Nov 2002, 14:27 |
Anmeldungsdatum: 25.06.2002
Wohnort: Direkt an der badisch-schwäbischen Demarkationslinie - in Möhringen/Baden
Hi Sierra,
I doubt that you will find something "off the shelf" that meets your needs. At the moment, I am producing some flares for my Patrol using rubber belt material. To fix them to the fenders I will use the given joints to which the original flares (that were too large for my tires) were attached.
Hope this helps!
Greets, MartinRR |
_________________ Herzlichst, MartinRR
Life without love? Impossible! |
| andrewm |
Verfasst am: Di, 05. Nov 2002, 11:31 |
Anmeldungsdatum: 20.06.2002
| andrewm |
Verfasst am: Mi, 06. Nov 2002, 11:46 |
Hi all,
Just got a mail from 'Guest' asking where I got my 'fender flares' ... (Would have replied in the mail, but is a bit hard to reply to 'guest'...) :(
Its a bit hard
Mine are not exactly the same as the casty but look very similar, and I got them from Tom's Fahrzeug Technik.
http://www.toms-fahrzeugtechnik.de/
Andrew |
_________________ It must be Thursday, never could quite get the hang of Thursdays...
Arthur Dent, The Hitchhikers Guide to the Galaxy |
| Sierra |
Verfasst am: Mi, 06. Nov 2002, 15:40 |
Hy Andrew,
My mistake...I am not yet fully familiar with the tools to use on this board to answer a message...so I sent you an Email
Thanks for the info on the fender flares. I will get them from Tom's when I get back next week.
Sierra |
