The 3D4D engine is suppose to run only on low sulphur diesel.
Within Europa it,s all fine.
What if I go ahead on going overland to ZA, and I,m unable to find such diesel on the road?
I would appreciate your opinions.
FUELHi,
The 3D4D engine is suppose to run only on low sulphur diesel. Within Europa it,s all fine. What if I go ahead on going overland to ZA, and I,m unable to find such diesel on the road? I would appreciate your opinions.
Then.... you should have bought a BJ45 with 3B engine... That can handle ANY fuel quality
Donno much bout engines, I just know there is devices to test fuel quality before you pour it in... If I was you I 'd organise one of those so you can at least choose the best avaliable option... Suche den DURCHBLICK (und W-Lan spots in MAROKKO!!!!)
ThanksThanks Sammy, but,...
This,s what I got...and I didn,know about that whole thing after I payed for it. Anyway, if there is a way to know about the fuel tester, pls let me know. Thanks again
Hola Sevil:
1. You'll just fill'er up with whatever you get and drive. 2. Perhaps some STP product will reduce soot; I'm skeptical. 3. An additional diesel filter can reduce solid impurities. 4. Check the injectors more frequently, they suffer most from dirty diesel. Muchos saludos, don Matías. MATTHIAS BODE
COCHABAMBA/BOLIVIA S 17.35775, W 066.14577, 2'740 m ue. NN.
Zurück zu Multi Language Board!
Mitglieder in diesem Forum: 0 Mitglieder und 1 Gast
