http://4x4ph.com/forum/index.php?showtopic=68557
Die Bilder sind nur sichtbar, wenn man dort angemeldet ist, deswegen habe ich mir erlaubt, sie hier sichtbar zu machen:
BJ 60 fully restored
In einem weiteren Beitrag bei 4x4ph.com sind dann die folgenden Details aufgezählt:
"1987 Toyota Land Cruiser 60 Series (BJ 60)
Exterior:
Subaru blue metallic paint
ARB Winch bullbar (front)
ARB Rear bumper with built-in tow hitch receiver
ARB Roof rack with optional mesh flooring
ARB style Rock slider stepboard
WARN 8274-50 Electric winch (front)
WARN M9000 Electric winch (rear) on a detachable hitch mounting plate
Original Toyota Land Cruiser 60 series snorkel
Raybrig Clear H4 headlight lens
Toyota Original South African spec sidemirrors
Interior:
Original factory upholstery
Built-in rear drawer system
Sub-woofer enclosure installed in the rear drawer system
Upgraded sound system by Kelvin Go of Audioessentials
Engine and Drivetrain:
Toyota 3B diesel engine
Freeflow exhaust system by Mufflerland
ARB High volume air compressor with optional tire inflation system
ARB Air lockers on front and rear differentials
ARB Air Locker heavy duty airline kit for front and rear differentials
Toyota Original 4.88 ring gear and pinion ratio for front and rear differentials
Original Toyota heavy duty double bearing differentials
Extended differential breathers in the engine bay
Upgraded brake system to accommodate large tires
Suspension and brakes:
3inch lift Parabolic leaf spring (Front and Rear)
Rancho RS 9000x front and rear shock absorbers
Old Man Emu steering damper
super heavy duty greasable anti-inversion shackles (Front and Rear)
Ironman greasable shackle pins
U-bolt flip kit for front and rear differentials
Stabilizer link extension
Full polyurethane bushings
Stainless steel braided brake lines on differentials and axles
BF Goodrich Mud Terrain KM2 tires (255/85 R 16)
4x4 Engineering Mag wheels by Bradley Japan( 7 x 16, -15 offset)
Full restoration done by Dr. G’s Car Clinic"
