Toyota Land Cruiser PZJ 75 Wohnmobil Expedition-ready
Postby Maglov » Sat 29. Jul 2017, 21:07
Hi everybody,
My beloved expedition vehicle, Toyota PZJ 75 Troop Carrier 1991, is for sale. It is pure classic, with 1PZ engine, which is a 5 cylinder version of 1HZ engine, 24V electric system, leaf springs front and rear 6 bolt rims and other marks of the authentic heavy-duty troop-carrier, tough and reliable, built to last.
I have bought it 8 years ago from a member of this forum. I had a great experience with it, especialy in Asia, but it have been in Africa as well, with the first owner .
Technically the car is in very good condition I would say excelent, it was always looked after and well maintained. The body is with no complaints, the paint is very good, no rust! I have stored about 80 L of oils for the engine, gearbox, front / rear differential and greases for future maintenances, and other parts, all of these goes with the car. It has full service history also from the first owner.
After the last trip, it got a major upgrade - new tires, rims, new Dobinsons Suspension Lift Kit, spacers etc. Recently this year, it was upholstered and got new exhaust and tinted back windows.
When I bough it, it was registered as a camper "Wohnmobil", it is registered in Bulgaria the same way now. The car is located in Sofia, Bulgaria. Due to the recent refurbishment, some of the extra equipment is not fitted back to the car at the moment, but can be done easily.
Technical data:
Mileage - 226,368 km
Cubic Capacity - 3469 ccm
Power - 85 kW (116 PS)
left-hand drive
Number of Seats – 2 by registration, there is another one on the back which turns 360 degrees.
Door Count - 2/3
Manual gearbox
First Registration – 1991
24V
HU 06/2018
description and special equipment outside:
- LSD on the rear axle
- manual locking hubs
- Dobinsons suspension kit : 50 mm lift, +40 kg front axle and + 300 kg rear axle
- extra fuel tank 150 L
- 5 x BFgoodrich 285/75 R16, condition - like new
- 4 x 25 mm Wheel spacers
- snorkel
- Hi-lift Jack, can be mounted on the front bar or on the roof-carrier
- 40 L Propane tank, mounted under the body for heating , cooking and refrigerator eventually, never used.
- 3 x roof-rack, one of them is large aluminium box 42х142х107 cm, cannot be used all together with the roof tent, My usual combination is one roof rack and the tent, but I have also fitted all of 3 together on top, without the roof tent
- 6 x aluminium boxes approximately 60x40x20 cm, all of them are with locks, never used them,
- 2 x aluminium Recovery Board (1,5m)
- roof tent “Air Home” 1,80x 2,00 m, a bit old, but still good and spacious.
etc.
description and special equipment inside:
- 120 L stainless steel water tank, if used, it goes to the place of the third seat
- refrigerator Englel 30 L
- air compressor, not mounted
- sun-shield tinted rear windows
- 4 x snow chains RUD, very good in mud and sand as well
- 24 volt to 12 volt DC/DC converter,
- 100 A battery
- foldable table
- two custom benches with storage space inside, with extra plywood piece it becomes one flat surface, perfect for sleeping inside
- 2 of the original benches, not mounted but I still keep them
- etc
The price is 17 500 EUR, although it could be negotiated a bit.
Do not hesitate to contact me regarding this advert at:
00359 897 520096 WhatsApp and Viber available
or
rmaglov@gmail.com
I speak English but it is possible to answer an email in German.
automatic German translation follows below:
Toyota Land Cruiser PZJ 75 Wohnmobil Expedition-bereit
Hallo allerseits,
Mein geliebtes Expeditionsfahrzeug, Toyota PZJ 75 Troop Carrier 1991, steht zum Verkauf. Es ist reine klassische, mit 1PZ Motor, die eine 5-Zylinder-Version von 1HZ-Motor, 24V-Elektro-System, Blatt Federn vorne und hinten 6 Schraube Felgen und andere Marken der authentischen schweren Truppenträger, hart und zuverlässig, gebaut letzte.
Ich habe es vor 8 Jahren von einem Mitglied dieses Forums gekauft. Ich hatte eine tolle Erfahrung damit, especialy in Asien, aber es war auch in Afrika, mit dem ersten Besitzer.
Technisch ist das Auto in sehr gutem Zustand Ich würde sagen, excelent, es wurde immer gepflegt und gut gepflegt. Der Körper ist ohne Beschwerden, die Farbe ist sehr gut, kein Rost! Ich habe etwa 80 L Öle für den Motor, Getriebe, vorne / hinten Differential und Fette für zukünftige Wartungsarbeiten und andere Teile gelagert, das alles mit dem Auto geht. Es hat volle Service-Geschichte auch von der ersten Besitzer.
Nach der letzten Reise bekam es ein großes Upgrade - neue Reifen, Felgen, neue Dobinsons Suspension Lift Kit, Spacer etc. In diesem Jahr wurde es gepolstert und bekam neue Auspuff und getönten Rückseiten.
Wenn ich es baue, wurde es als Wohnmobil registriert, es ist jetzt in Bulgarien registriert. Das Auto befindet sich in Sofia, Bulgarien. Aufgrund der jüngsten Renovierung, einige der zusätzlichen Ausrüstung ist nicht wieder auf das Auto im Moment montiert, aber kann leicht gemacht werden.
Technische Daten:
Kilometerstand - 226.368 km
Kubische Kapazität - 3469 ccm
Leistung - 85 kW (116 PS)
Linkslenker
Anzahl der Sitze - 2 durch Registrierung, dort ist eine andere auf der Rückseite, die 360 ​​Grad dreht.
Türzähler - 2/3
Schaltgetriebe
Erstregistrierung - 1991
24V
HU 06/2018
Beschreibung und Sonderausstattung außerhalb:
- LSD an der Hinterachse
- manuelle Sperrnaben
- Dobinsons Fahrwerk: 50 mm Hub, +40 kg Vorderachse und + 300 kg Hinterachse
- zusätzlicher Kraftstofftank 150 L
- 5 x BFgoodrich 285/75 R16, Zustand - wie neu
- 4 x 25 mm Spurverbreiterungen
- schnorcheln
- Hi-lift Jack, kann an der vorderen Stange oder auf dem Dachträger montiert werden
- 40 L Propan-Tank, montiert unter dem Körper für Heizung, Kochen und Kühlschrank schließlich, nie verwendet.
- 3 x Dachträger, einer davon ist aus großem Aluminiumkasten 42х142х107 cm, kann nicht alle zusammen mit dem Dachzelt verwendet werden, meine übliche Kombination ist ein Dachträger und das Zelt, aber ich habe auch alle 3 zusammen oben, Ohne das Dachzelt
- 6 x Aluminiumboxen ca. 60x40x20 cm, alle sind mit Schlössern, niemals benutzt,
- 2 x Aluminium Recovery Board (1,5m)
- Dachzelt "Air Home" 1,80x 2,00 m, etwas alt, aber trotzdem gut und geräumig.
etc.
Beschreibung und Sonderausstattung innen:
- 120 L Edelstahl Wassertank, wenn verwendet, geht es an die Stelle des dritten Sitzes
- Kühlschrank Englel 30 L
- Kompressor, nicht montiert
- sonnenschild getönte Heckscheiben
- 4 x Schneeketten RUD, sehr gut auch in Schlamm und Sand
- 24 Volt bis 12 Volt DC / DC Wandler,
- 100 A Batterie
- faltbarer Tisch
- zwei kundenspezifische Bänke mit Stauraum innen, mit extra Sperrholz Stück wird es eine flache Oberfläche, perfekt für das Schlafen im Inneren
- 2 der ursprünglichen Bänke, nicht montiert, aber ich halte sie immer noch
- etc
Der Preis beträgt 17 500 EUR, obwohl es ein bisschen verhandelt werden könnte.
Zögern Sie nicht, mich über diese Anzeige zu kontaktieren:
00359 897 520096 WhatsApp und Viber vorhanden
oder
Rmaglov@gmail.com
 Ich spreche Englisch, aber es ist möglich, eine E-Mail in deutscher Sprache zu beantworten.
more pictures to come...
Maglov
Re: Toyota Land Cruiser PZJ 75 Wohnmobil Expedition-ready
Postby Maglov » Sat 29. Jul 2017, 21:19
Maglov
Postby Maglov » Sat 29. Jul 2017, 21:33
Maglov
Postby Maglov » Tue 1. Aug 2017, 14:00
Aufgrund mehrerer Anfragen zum Verkaufsprozess möchte ich es klarstellen. Es gibt nichts Ungewöhnliches im Auto Export / Import zwischen Ländern in der EU, in der Regel ein Verkauf Vertrag gemacht wird, als das Auto kann mit temporären Registrierungsschildern in das Zielland in der EU und registriert werden. Die Registrierungsschilder kosten etwa 25-30 EUR und die Versicherung vermutlich für ca. 30-40 EUR. Natürlich bin ich bereit, dieses Verfahren in Bulgarien vollständig zu unterstützen. .
Maglov
Postby Maglov » Sat 12. Aug 2017, 20:23
Neuer Preis - 16 900 EUR
Maglov
Postby Maglov » Fri 15. Sep 2017, 21:02
Some more pictures from bellow as requested, and beyond :D :
Maglov
Postby Maglov » Fri 15. Sep 2017, 21:03
According to questions regarding the Toyota, I am updating some of the information.
A discount price of 15 200 EUR For those, not interested of the removable equipment, marked in RED in the following list.
- snorkel
etc.
- 6 x aluminium boxes approximately 60x40x20 cm[color=#FF0000] all of them are with locks, never used them, [/color]
- 100 A additional battery for the fridge, etc.
- foldable table
- etc
I can arrange the truck to be transported to Germany or Austria, for 300-400 EUR, depending on where exactly.
For other destinations any other questions , do not hesitate to ask.
Maglov
Return to Marktplatz Fahrzeuge / Vehicles: Land Cruiser & FJ Cruiser
Users browsing this forum: No registered users and 6 guests
