http://www.2machenblau.de sind mit Elektrikproblemen in Arizona gestrandet und brauchen die Hilfe von J8 DIESEL Elektrik Spezialisten!
Auf Facebook und IH8MUD sind schon alle am rühren aber mit dem Thema Diesel Elektrik, die offenbar auch noch modifiziert wurde, überfordert.
Link zum IH8MUD Thread:
https://forum.ih8mud.com/threads/hdft-f ... t-13871478
Link zum Facebook Thread:
https://www.facebook.com/groups/TLCAsso ... 9058006719
Wer kann soll bitte helfen damit die beiden ihren lange geplanten Traum nicht zerplatzen sehen!
I know @wngrog hosted these guys and is aware of their situation, but I wanted to post up on here to see if anyone can help them out. Really cool couple with a killer 80 series camper conversion with a previous HDFT/A442F (manual converted to auto as I understand it) has fried some wiring. They're stranded in the Phoenix area with the dash pulled and tracing fried wiring. They may need a wiring harness or may need just some wiring help.
You can reach them on IG @ 2machenblau.de Or reach out on here and I'll try to link them into this thread. Tag anyone that might be able to help.
As I have it from them on the sequence of events:
- stopped at a viewpoint, engine & AC running.
- took pictures, wants to drive off.
- when switched from P to D we noticed the AC\Blower not working, dash completely dark and no gauges working beside the fuel.
- Guage fuse 10A was blown
- replaced it and blown again after 2s in the 2nd key position.
- a shop in Alpine AZ towed us and started the investigation, used a 30A fuse in the gauge socket. not sure how much of the discovered damage was caused by this.
- then we removed part after part from the IGN line but still blowing.
- engine will not start as the 12-24v timer relay needed IGN too
found a melted wire behind the fuse box and removed today the dash completely to discover more melted connectors. these connect the dash harness with the engine bay. not sure how far this damage leads. dash wiring has several melted spots.
- root cause still unclear.
- ABS connector in engine bay is melted too.
