Auch wieder futsch....;((
Einige Motor-Daten & -Kennzeichnung kam neulich aus der 100-Series Mailinglist:
xxxxxxxxxxx
G'day again,
More information has landed...
The engine is designated "1VD-FTV", is 4461cc's and in VDJ76, 78 & 79 series
will be a turbo and intercooled 151kW and 430Nm (exactly the same specs as the
1HD-FTE in the HDJ100).
Regards,
Greg.
-----Original Message-----
Hi Guy's,
As per recent discussion, the new "200" series will feature a 4.5L twin
turbocharged diesel engine, 200kW and 650Nm, backed by a 6 speed automatic. This
will be released in October 2007. It will also have an independent front end
with coil springs, top models will feature Kinetic dynamic suspension - a
development of the system originally designed in Oz many years ago.
The 7* replacement will feature the same V8 diesel with single turbo, ~150kW &
440Nm, which we will see in May 2007. A 4 door low roof Troopy version is
rumoured to be on the cards, along with the natural progression of that - a dual
cab utility
xxxxxxxxxxxxxxxxxxxxxxx
