BJ-73 Windshield-Frame Anticorrosive Treathment???
To simplify the board system...
LULO_Adventure
Beitrag von LULO_Adventure »
There any specific treatment or work to prevent corrosion in the windshield-frame? :?: :?: :?:
...a friend told me that a good treatment is to apply foam piloiuretano inside the frame.
I also commented that care must be taken when using polyurethane foam as it can even bend the metal, so I will comment that there are different types of polyurethane foam, even my cousin told me the ability to galvanize the frame ???
Vielen Dank :wink:
LULO Adventure
Land Cruiser LJ-70´88 (Soft Top)
A Coruña - España (SPAIN)
"Eres lo que has viajado"
landcruiser
Re: BJ-73 Windshield-Frame Anticorrosive Treathment???
Beitrag von landcruiser »
LULO_Adventure hat geschrieben:...
He couldn´t be a real friend! :lol:
Never do so!
Spraying Fluid Film, Mike Sanders or other like this in the cavities is an approved method prevent fouling.
LULO_Adventure
landcruiser hat geschrieben:
"Spraying Fluid Film" ??? :?: :?: :?:
Vielen Dank :wink:
LULO Adventure
landcruiser
google is your real friend :lol:
http://www.fluidfilm.de/
LULO_Adventure
landcruiser hat geschrieben:google is your real friend :lol:
http://www.korrosionsschutzshop.de/
Thanks "amigo"! :wink:
LULO Adventure
Reiti
Beitrag von Reiti »
Most of the foams will soak and keep water, perfect conditions to grow rust.
A fat like Mike Sanders is a pain in the ar.. to work with, but it will work.
Willem Jan Markerink
LULO_Adventure hat geschrieben:BJ-73 Windshield-Frame Anticorrosive Treathment???
Vielen Dank :wink:
Polyurethane foam, the yellow stuff used in building construction, will do nothing to protect the metal itself, while it will do everything possible to trap moisture, when (not *if*) it will find its way inside.
Imagine a leak in your roof, because of a bad antenna hole....a water-trap in the A-pillar could even cause it to burst during winter....have seen it happen on improvised shelter poles/pedestals....only thing they would have had to do, was drill a drain hole on the bottom of the pole, that would have kept the structure alive for decades....now it was toast within one winter....
Or imagine submerging the vehicle in a river....you would never get rid of all the water inside....
(J.R.R. Tolkien)
(WJM....;))
Zurück zu „Multi Language Board!“
