Hello,
i have any new and used parts for sale - all its for TLC HZJ78 / Y2001
ORIGINAL TOYOTA parts::
1x NEW not used - original front Toyota diferential STD / ratio 4,3 / non locker / price 850 Euro
1x NEW not used - FRONT Acutator, differential lock shift (Stellantrieb Differentialantrieb VA -Sperre) /price 400 Euro
1x ARB locker RD132 / front axle / not used original packing / 800 Euro
3x set: bush + needle bearing for steering knuckle / price 60 Euro / set
5x set: oil seal sub assy / steering knuckle / 36 Euro /set
1x set brake shoe kit / rear brake drum axle / 75 Euro
1x pulley, clima compressor idle / 88440-35010 / 55 Euro
NEW OEM parts:
6x bearing set for axle hub (2 bearings + oil seal) / price 47 Euro per set
2x front universal joint / propller shaft / 24 Euro / pcs.
2x rear universal joint / propller shaft / 25 Euro / pcs.
6x bearing for steering knuckle arm / price 27 Euro / pcs.
CPRO parts:
front disc caliper piston - Material: stainless steel – CNC production, Dimensions: dia. 42,8 / length 28,3 mm / Price: 10 Euro / PC
1 set: NEU 4 Stck. Spurverbreiterungen HZJ 5-Loch / 5x150 mm / M14 x 1,5 mit 20 Stck. Mutter / 30 mm Stärke (60 mm pro Achse), Preis: 190 Euro / without TUV / Czech Production
1 set: aluminium bonnet metal protective plates silver (set of 3 pcs.) / 135 Euro
USED parts:
HZJ78 / HZJ78 model 2001 / Passenger very good condition without damage, driver good condition with rip, Seats are without rail mechanism / price total 50 Euro
Please send me info about PN.
Regards
Jan
