supertramp hat geschrieben:Thanks for sharing your adventures!
I just discovered that Eric from Campteq is back in business with an upgraded version uf the pop top. How‘s your top working out for you so far? Any issues or complains?
Cheers, Neil
Hey Neil,
The upper and lower aluminum are original, but we had to redo the tent material and mosquito netting. We also replaced the hinge since the original broke on the previous owner in Baja and he put on gate hinges that we replaced with a beefy piano hinge that is bolted and sikaflexed into place instead of the Tig welded original that didn't hold up to the flexing. We replaced the gas struts with stronger ones.
The whole top is sikaflexed on instead of bolts and that's held up perfectly. No issues.
The back tends to leak in the rain so we added a back flap for that and the sides leak so the new design with a little "skirt" of material mostly takes care of that I bet.
So, all of that being said, I think the new ones take care of most of the issues.
