-- Roof HZJ75 long wheelbase |
| Maurice |
Verfasst am: Mo, 05. Apr 2004, 09:55 |
Anmeldungsdatum: 05.04.2004
Unfortunately I trashed my roof (righthand-front) against a steel construction over the exit of a parkingdeck. Entering was no problem, but when I tried to leave the parkingdeck I found out the exit was about 20 centimeters lower than the entrance.
So I'm looking for an new (second hand) roof. I've seen lots of pictures of cars like mine which have new camperroofs. I wonder if anyone might know anyone who has the original roof and wants to sell it.
Any suggestion is welcome!
Thanks!
Maurice
Holland |
| Albert |
Verfasst am: Mo, 05. Apr 2004, 13:13 |
Anmeldungsdatum: 29.04.2003
Hello Maurice,
I don't know, if the original roofs are re-useable when replaced with a camper roof. Therefore, it might not be a bad idea to contact some of the vendors of such camper roofs first. They may also be able to help you in finding an orignal roof if applicable.
You may find some vendors of these camperroofs here: Buschtaxi.de/Marktplatz/Partner
Regards,
Albert |
_________________ Keep the rubber side down! |
| andrewm |
Verfasst am: Di, 06. Apr 2004, 19:55 |
Anmeldungsdatum: 20.06.2002
The companys that install these rooves (roofs?) only cut holes into the top... they do not remove the whole thing.
You will probably have to look at getting this fixed someother way... maybe a call to a wreckers yard in South Africa or Australia... I don't know of any wreckers who do toyota in Germany.
Andrew |
_________________ It must be Thursday, never could quite get the hang of Thursdays...
Arthur Dent, The Hitchhikers Guide to the Galaxy |
| Maurice |
Verfasst am: Mi, 14. Apr 2004, 06:56 |
Thanks guys, I'll continue my "quest"....
Maurice |
| MarkusZ |
Verfasst am: Di, 20. Apr 2004, 11:51 |
Anmeldungsdatum: 14.11.2001
Hi Maurice,
Just a few weeks ago there was a 75 Model offered in mobile.de being parted out in Holland.
On the other hand I could well imagine your damaged roof being restored at a reasonable rate by a crafty (maybe Polish) mechanic.
Anyway - without picture any advice has to rely on mere guesswork. Maybe you could provide one.
good luck
Markus |
| andrewm |
Verfasst am: Mi, 21. Apr 2004, 15:47 |
Hi MarkusZ,
I know that Tom's Fahrzeugtechnik can get complete replacement bodys... but will probably be tooo expensive if you just want to fix the hole in your roof...
http://www.toms-fahrzeugtechnik.de
Andrew |
