I'm sorry my German is not very good.
I have a new 2010 Toyota Hilux 3.0 D4D. I am taking it to Africa. At present it has 265/65 R 17 Duellers on alloy wheels. I wish to fit steel wheels with BF Goodrich All terrains. I believe there can be a problem with a 16 wheel and the brakes. British companies are starting to make a 8 x 16 wheel with -7 offset but it will not be available for 2 months. I go to Africa in 1 month!
Nestle in Stuttgart fit original toyota 7.5 x 17 and 7 x 16 wheels to the vehicle.But they are 5 hours away from me. They will not give me the Toyota part numbers to give to my local dealer. help!
Any ideas would be most welcome.
John
A question in English (sorry!)
Re: A question in English (sorry!)
Hi John,
you can fit 8x16 on you´r 3.0 D4D!
I drive 8x16 with cooper STT 285/75R16 on my 3.0 D4D and have no problem whit the brakes!
I get the rims here--> http://www.daktec.de/Felgen.html
On this pic you can see the 8x16 rims from Nissan Patrol (offset +10mm) on my truck -->
Good luck!!!
Good luck!!!
Freundliche Grüße aus Stuttgart
Roman
10´ Lux-Exe
Mods: Hopa-Box 200Ps/410Nm, OME mittel/weich, 285/75R16 schwarze "Patrolfelgen", Speedliner, Steinschl.-Folie an Flanken, Konserviert mit MS-Fett/FF, AEROKLAS e-Ladefl.abd./Mudguards,2x Kompressor, HA ARB-Airlocker, 5,4t-Winde ...
Roman
10´ Lux-Exe
8x16 steel should not be a problem! Have fun in Africa!!
Thanks guys, very helpful,
My Hilux model number is KUN26R-PRMSYW - is that the same as yours Roman?
Did you change the suspension?
You bought 8x16 with +10mm offset?
Thanks again
John
Thanks again
John
Hi John,
I don´t know the model number of my, but I kow that my truck have allready the bigger stock breaks.
Yes, I fit the 8x16 with +10 offset, a offset +15 should be work too.
You can order rims like mine here --> http://www.daktec.de/Felgen.html
ou can get other rims here --> http://www.google.de
Yes, I install a OME-suspension kit. I order my OME-suspension kit here --> http://www.muer-4x4.de/
How to install -->
reparaturanleitung-fahrwerksumbau-dampfer-feder-an-der-va-t25641.html
reparaturanleitung-ha-blattfeder-dampfer-tauschen-t25647.html
How to fit 285/75R16 (33" tires) --> umbauanleitung-fur-285-75r16-t26224.html
Have a look --> http://www.newhilux.net/
How to install -->
Roman
10´ Lux-Exe
Roman
10´ Lux-Exe
Hi Roman,
Daktec are sold out! Typical.
Another guy has suggested the following original Toyota part numbers: 42611-60420 is a 17x6JJ from a LC120 Prado or 42611-35310 is a 17x7.5JJ from a LC120 Prado. Nothing in 16" though
These will both fit the new larger brakes he says.
I will check availability tomorrow.
John
John
